S600 woes.......
210 E 55, 220 S 600
S600 woes.......
Ok, I am in hopes that someone can shed some light on to my situation...about a month ago, I started to get CEL, found out that I was having cylinder7,8,9 were misfiring....gone through whole bunch more test and came to conclusion that I needed to replace, the left bank coil pack, wiring harness (due to oil leak), o2 sensor, MAF sensor, plugs, and injectors.....after almost $5K in repair bill, it still misfiring in cylinder 8 and 9....I am totally lost here and so is my mechanic.....any advise would be hugely appreciated it. Help out a fellow member please...any certified technicians out there with some idea?
Thanks in advance.
Thanks in advance.
210 E 55, 220 S 600
BMW E30. I've turned to the dark side.
if your car is a non-turbo S600, the cylinder shut-off system has been known to be problematic and cause misfires on the left bank. a dealer can check and change that coding. BUT, that misfire might be a little more random than what you're experiencing. i'm hoping the oil sensor that causes oil entry into the harness was replaced already. i seem to recall a campaign to that effect.
unfortunately the above only applies to '00-'02 model years.
i see that oldschoolrice is a fellow dimer. i smell a thread jack, whacha got in it?
210 E 55, 220 S 600
thanks...
210 E 55, 220 S 600
Injector was....
it turned out that you were right......they ran some test on the injector read out and found that the injector for cylinder 7,8 and 9 were bit off. So, they took the fuel rail off and found that it had some debris....they changed the injector and the car runs so much better. I can still feel bit of misfire but no CEL comes on and I will see if it will pass the DEQ. I am much relieved but can't say that i am happy that it cost me another $1200 to get this point. Also, found out that my indy mech put in a wrong injector in cylinder 7.....lost all faith in this guy. Going to get some money back from this guy for sure. I kept the work order open just in case with the dealer.......thanks again for everyone's response and input. I love this forum.
