Silly Question? IDK...
fleet vehicle
Okay. This may be obvious to those who understand this stuff but could somebody explain this...?...
I have a C-coupe. I have a Jeep.
The C-coupe specs, horsepower: 189 hp @ 5800 rpm and torque : 192 lb-ft @ 3500 rpm
with a curb weight between 3250-3280 pounds. 6 speed manual. 0-60: 7.6 sec.
The Jeep Cherokee specs, horsepower: 190 hp @ 4750 rpm and torque : 225 lb-ft @ 3000 rpm
with a curb weight between 2891-2993 pounds. 4 speed Asin-Warner AW4 automatic. 0-60: 11 sec.
The Jeep is a slug.
The C is quick.
Aside from the obvious (yes one a Mercedes/car, the other a Jeep/truck), why such a huge difference in straight line acceleration?
The Jeep is a slug.
The C is quick.
You've got the curb weight wrong for the Jeep--it is NOT lighter than the C.
Light wheels make almost no difference whatsoever.
fleet vehicle
This is the old XJ chassis, not the current Grand Cherokee.
The coupe information I have is perhaps suspect. The only weight reference in the manual is the roof load limit.
The door jamb label list a GWR of 1900kg or 4185lbs.
With no curb weight info at hand, I searched the web and found one here:
http://www.modernracer.com/mercedesbenzc230coupe.html
Perhaps these guys got it wrong. I don't know how to (or if you can) extract a curb weight from the GWR.
I realize their HP peaks arrive at different revs, I just don't know what that means in the real world.
Based off Edmunds.com, your Jeep is 3354lbs, and your C is 3250lbs. Reasons why your C is faster- Jeep has larger diameter tires, more drivetrain power loss due to a transfer case and front driveshaft/axles, auto trans (yet again more drivetrain loss vs. a manual trans), weighs more, less aerodynamics, gearing mean't for lower end power (not speed), engine designed for low end power, ect.
