SRS Failure and then ESP failure
Old Aug 24, 2008 | 04:53 PM
MB-JIM's Avatar
06 C 350 2014 GLK350
My 06 C350 with 18,000 miles showed SRS failure for three days. That fault indication went away and then the orange triangle lit up while out last night. Also, at that time, the cruise control wouldn't work. Today, while out, there were no faults indicated. What is happening?
Old Sep 14, 2008 | 11:15 PM
keith100's Avatar
2008 c300
Don't really know, except that the CC doesn't work if the ESP is on.
Aren't you under warranty still? See the dealer.
Old Sep 15, 2008 | 10:36 AM
Diesel Benz's Avatar
You mean CC does not work if ESP is off? I haven't even tried.
Could you have suffered from low battery? Other options are the brake light switch for CC and the weight sensor for the SRS system, completely unrelated issues in that case.
Old Sep 15, 2008 | 09:34 PM
keith100's Avatar
2008 c300
I haven't tried CC with ESP off either, but my w204 handbook says CC switches itself off if:
you turn off ESP.
ESP activates itself.
Makes sense really. CC would be trying to keep the car at say 60, when the ESP is trying to tame it!
Old Sep 18, 2008 | 12:54 AM
MBSPEC's Avatar
Everything
Take your vehicle in the dealer, still under warranty. Factory warranty is 4 years & 50,000 miles. Sounds like you have a bad steering angle sensor, will cause SRS & ESP light come on. Cruise control won't work if ESP light is on.
Old Sep 19, 2008 | 01:56 AM
GlockDaddy's Avatar
2000 C230 Kompressor
Sounds like the car was built during Fasching...
Old Sep 28, 2008 | 08:33 PM
KarlBenz's Avatar
Mitsubishi Outlander 2012 AWD
ESP fault caused by bad N49 steering angle sensor common problem for this model 211 Easy fix under warranty
