Unusual turn signal problem
I think the problem might be in the wiring harness that enters the headlight housing.
That is the main feed for the electrical for the whole light assembly, headlight, highbeam, turn signal.
Dave
I have power to the 4 drivers side black w/white stripe wire.
It is either not getting the ground from the big brown wire, or the power is not going through the headlight assembly to the bulb socket.
Here's what i found.
The computer in the car stops the voltage to the wire as soon as it detects a open fault and does not restore power to that wire until the key has been re-cycled.
The problem with my car is that the bulb socket metal tabs do not make contact with the headlight housing when the socket is fully rotated in the headlight housing on the drivers side, pass side is OK.
Don't know why, possible plastic wearing or manufacturing tolerance issues, but i digress.
The way to fix it is to take 2 wires with very small female spade connectors on the 2 wires.
Carefully plug the 2 wires into the headlight housing with the main wiring harness that goes to the headlight housing unplugged.
On the C230 the turn signal wires are the 2 bottom wires, big brown which is ground and black with white for drivers side, or black with green for pass side.
Hook up a test light powered in series with 1 wire and ground the other,
Or use a volt, ohm meter like i did.
Rotate the turn signal socket until you have the test light lit, or have continuity with the VOM.
That's it, remove the wires and plug in the main wiring harness to the headlight housing and you will have a working turn signal.
Dave
