ML320 Crank Position Sensor - what tool 2 remove?
Old Sep 7, 2008 | 04:26 PM
w_cohen's Avatar
ML320
I am positive my ML 320 (1999) has a failing crank position sensor (CPS).
I have located the sensor and it seems to have a star head screw holding it down. Anyone know what size star socket I need to remove it with? I assume a 1/4" drive works best.
Also, as it is a very tight fit with limited available room what accessories should I also get/use with the socket I obtain (how many/long extensions, universal joint, etc).
I'd like to try the replacement myself but if it is too difficult then I'll take it to a dealer.
Thanks,
Walter
Old Sep 11, 2008 | 02:39 AM
deuxslow's Avatar
W215
I just replaced this in our C320 yesterday...Use a regular 6mm socket with 2 6 inch extensions. I bought a U-joint but I never used it, it was to difficult. And yes...1/4 drive is what you need. Torx(star) sockets are not absolutely neccesary either.
Old Sep 11, 2008 | 08:31 AM
azinn's Avatar
2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
Thanks,
Walter
Plenty of info here http://www.mercedesshop.com/shopforu...ht=replace+cps
Old Sep 11, 2008 | 12:33 PM
lkchris's Avatar
'10 CL550, '12 GL550
The screw is external Torx wrench size E8.
Old Mar 17, 2009 | 02:07 AM
deepdubey's Avatar
Picture of the location of cps on 99 ml320
Thanks,
Walter
Hi, Can you upload a picture of the location of the crankshaft position sensor. I saw the picture on another thread but it wasn't clear and I wasn't able to locate the cps.
Deep
Old Oct 8, 2009 | 08:45 PM
Racerx18691's Avatar
Mercedes ML430
My ML430 CPS needs to be replaced as well. Can the CPS be reached without taking the engine cover off?
Old Oct 8, 2009 | 11:15 PM
lkchris's Avatar
It lifts off in a heartbeat, doesn't it?
On my W210 it was invisible in any event, but if you removed most of the air filter/intake system you could at least see it from the passenger side (but you couldn't reach it).
Just think about it--if it's reading crankshaft revolutions, it's reading them from the flywheel. That's just ahead of where trans connects to engine. If you were sitting in interior of car, think 10 o'clock.
Old Oct 8, 2009 | 11:29 PM
Mercedes ML430
thank you. I will try it.
