Engine missing possible throttle accuator???
Old Nov 23, 2008 | 08:56 AM
GEDaggett's Avatar
1994 E320 (current)
have a 94 w124 e320. I believe the throttle actuator may be bad.
Here is what the car is doing.
At start up the car runs perfectly no problems. After almost exactly 3 minutes the car develops a rough engine and loss of power under acceleration. It almost feels like a car does when the Cat collapses and can't take any throttle without choking it out or you loose a cylinder on a four cyl engine. At first if I stayed on the throttle the engine would eventually clear up and accelerate as normal (typically 2 -3 seconds) at this point once the engine starts missing it will not clear up.
Additionally the car has engine surging at idle and in reverse at idle it is 200% worse
Here is what I have done.
Replaced 02 Sensor. (Ran the car for 2 weeks with the 02 unplugged before replacing and it made no difference)
Replaced MAF.
Checked and verified all coils are within specs for resistance.
Checked and verified Plug wires withing spec.
Verified the replacement of wiring harness.
Replaced OVP
I pulled the codes and got the following.
Pin 3
code 17 Data exchange malfunction between individual control module.
Pin 8
code 13 02S control system operating to rich for lean limit (replaced 02 Sens and it did nothing also drove it for a week completely unplugged and that had no effect either.)
Code 42 Can communication from ASR (I don't have ASR) EA/CC/ISC module
Pin 14
Code 9 CC/ISC Control Module
Code 5 Stoplamp switch
My question
Is there something I am missing. IS it possible that I have a sticking injector or valve sticking? What is the most likely thing to look at next? I don't want to just start replacing a bunch of $400 parts. Let me know anything you might think. Thanks
Gary
Old Nov 29, 2008 | 11:27 AM
MBTECH2003's Avatar
2000 ML 320, 2003 CBR600F4i, 99 Eclipse GSX
Diagnostic charges at shops are no where near as expensive as the parts you have already put into this car. Bring it to a shop and have it properly diagnosed. Hell i'll even take a look at it if you want to bring it to the city.
Kevin
Old Dec 16, 2008 | 08:10 PM
sun111's Avatar
190e 2.3
tps circuit or major vacuum leak
