C63 differential drain & fill plugs 17mm hex?
Old Jan 14, 2009 | 04:34 PM
qship5's Avatar
M5, C63, 335Ci
My 09 C63 with the 030 performance pack (with LSD) requires a differential fluid service at 1800 miles and I'm getting ready to do the work myself. My question is in regard to the fill and drain plugs and if they are a 17mm hex bit or something else.
I've ordered new plugs as I understand that they are to be replaced when performing the service, but they are not yet in at the parts counter.
Thanks in advance for any assistance.
Mike
Old Jan 18, 2009 | 02:59 AM
Eurosport's Avatar
monowiper
usually diff plugs are either 17mm or 19mm hex, if you go to your local Sears, they have a good set that included all hex 14mm-22mm (if i remember correctly) for pretty low price.
Some diffs have a washer on the plug some don't, just double check it before your final install. gl
Old Jan 18, 2009 | 11:57 PM
C32AMG/02's Avatar
Mike
An LSD clutch type requires, LSD Fluid or additive
Old Jan 24, 2009 | 03:51 PM
qship5's Avatar
M5, C63, 335Ci
OK, I did my diff service today and thought I'd share some info for anyone else who decides to do this themselves.
Drain and fill plugs are 19mm and require a normal socket to remove, not a hex/allen wrench type socket. When putting the plugs in, the tightening torque is 50nm. I bought the Castrol diff lube at a BMW dealer based on a post I read somewhere and it was way cheaper than at the MB dealer. The new drain plug listed for about $37, but with MBCA membership cost me $17. Total cost for parts was about $50 and change time was less than 1/2 hour.
Cheers!
Qship
Old Dec 9, 2010 | 07:08 PM
andy_c63's Avatar
2009 C63 AMG
Is it Castrol SAF-XJ 75W-140?
