203 (2001-03 C-class) tech bulletins
Old Jan 23, 2003 | 12:55 AM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
Exclamation 203 (2001-03 C-class) tech bulletins
More information on request. Enjoy:
-Tail lamp bulbs do not function due to high wattage going to tail lamps. Fixed by adding a resistor in series circuit to the tail lamps.
-Rumbling noise in rear axle area (VIN A274457-A358180)
-Engine performance complaint (C230 K 1.8 with auto trans.)
-A/C compressor switches on frequently
-C230K 1.8 oil leaks from front crankshaft seal
-2002 ESP warning light
-2002 & 2003 sliding/pop-up roof reverses
-Front turn signal bulbs inop due to contacts of bulb socket burning.
-SRS light on
-2002 Exterior mirror
-Display reads "Engine oil level above max." while driving
-Front cupholder broken. New, updated cupholder.
-2002 C230K replacement of lower left charge air hose
-Rear axle noise
-2002 Incorrect fuel gauge reading. Fuel level sender units
-V6 models rough idle/rough running/hesitation/won't start
-TeleAid remote unlocking inop
-A/C inop
-Windshield fogging above dash center outlet. Updated center vent outlet.
-COMAND does not respond to voice controls
-CD changer static or interference during CD changer playback
-Thumping noise from front axle while driving over bumpy road
-Poor AM/FM recpetion
-Transmitter key operating intermittently. Updated transmitter key
-203 wagon tailgate spoiler loose
-Front seat head restrint rattles
-Noises from shaft for front seat tilt adjustment
-Panorama roof panel does not open or move
-Trunk lid does not open
-Upper radiator crossmember mounting bolt breaking
-Noises from instrument panel/right A-pillar
-Purge valve "ticking" noise while at idle. Updated purge valve bracket
-Station wagon: pushbutton for rear side trim panel in luggage compartment is loose
-Accelerator pedal squeaks when pressed
-Door check noise
-Sliding/pop-up roof loses automatic function
-Squeaking noise from wiper blade on passenger side
-Backrest adjustment function does not work on semi-electric seats
-Poor AM/FM reception, vehicle can only be unlocked from within a small radius
-Noises from windows when fully raised/lowered. Window regulator failure.
Old Jan 23, 2003 | 11:36 AM
Mike T.'s Avatar
2005 smart cabrio; 2008 Mercedes-Benz B 200
more info, please
Can you post / link to these bulletins somehow? Thanks
Old Dec 15, 2005 | 04:26 AM
RednBlue's Avatar
w203/C180 (2001)
Can you provide me with more info on the clicking purge valve problem please, or a link.Thanks
Old May 15, 2006 | 01:57 PM
Pinklady23's Avatar
2002 C230 Kompressor Sport Coupe
Can you give me more info on the reception issues and the sunroof?
