radiator problem
Old Feb 13, 2009 | 04:46 PM
renard sylver's Avatar
clk500
radiator problem
I own a 2003 clk500 and heard about the radiator issue. Whats the best route to fix problem. Did mercedes ever own up to the problem
Old Feb 13, 2009 | 07:37 PM
acr2001's Avatar
2012 C300 4Matic
Check the sticker on your radiator to see if it is a Valeo. If so then you should replace the radiator. Search the forums for more info.
Old Feb 22, 2009 | 10:47 PM
brakel8's Avatar
ML500 AMG pkg
There is a service bulitin that explains how to identify the radiators with the issue. If it was my car I would go to the dealer and have them do a glycol test on the trans fluid. This will tell if there is any antifreeze in the trans, if there is the radiator needs to be replaced and the trans flushed.
