Stuck in PARK + BAS/ESP light....HELP!!!
Rating: Thread Rating: 2 votes, 5.00 average.
Old 01-19-2012, 09:05 PM
lito420's Avatar
ml320
Can someone please help!! I'm having issues similar to this
My 2000 Mercedes Benz Ml320 is shifting but not engaging. I looked at it, the gear position is moving form P- R-N-to-D but the car does not move so I towed my car to MB dealership. So I met Karin **, Service Adviser**. After she had check, she said I needed to change transmission and it might cost me $8,100. After that, I tried to call MB customer service MB USA 1-800-367-6372. Mr. Justine said he will find out what is going on with my car and he promised he will call me back with 24-48 hours. Since that day, I didn't get any answer.
Can someone please Help me out and let me know if there is anything I can do on my own to save my suv??
thanks in advance all help is appreciated.
Old 01-20-2012, 11:23 AM
lito420's Avatar
ml320
ML320 shifting but not engaging
Hey guys
can someone please help me trying to identify the problem my ML320 2000
is shifting but not engaging/Moving I towed the suv to the dealership only to find out that transmision need to be replaced for around $8,000.00 according to the dealership! MB will not cover this malfunction and super expensive repair. I can't afford this if someone knows of a way to fix this please let me know I really wanna save my ML it's been real nice to us and still a great Family car.
I'll appreciate the help.
Old 01-21-2012, 06:38 PM
biker349's Avatar
cl600
maybe linkage, or electronics problem. how many miles on your transmission fluid?
Old 01-22-2012, 09:13 AM
lito420's Avatar
ml320
It's an ML320 2000 with 160xxx miles,
never have change the oil on the transmission I'm the second owner,
the oil level it's fine but for some reason it's just not engaging any gear but does shift!!,
thanks for replying I appreciate your time and help.
Old 01-22-2012, 11:49 AM
biker349's Avatar
cl600
sometimes a transmission fluid change can help. if you've got over 60,000 miles on the car i'd give it a try.
Old 01-22-2012, 12:28 PM
lito420's Avatar
ml320
I already Did that without any luck any other ideas?
thanks.
Old 03-07-2014, 01:08 AM
  #32
CLK500 TWINS's Avatar
2001 S55 AMG Silver, 2003 CL600 Black Opal Metalic, 2005 CLK500 Silver (sold)& Orion Blue (sold)
Originally Posted by SoCal208
" The brake lights work fine when brake is pressed " DOES NOT mean the brake switch is OK. The brake switch is less than $20 with 15 minutes to replace. Have you try the pencil as pictures ?. If insert the pencil in the hole & you can be able to shift out of park, definitely IT HAS THE BAD BRAKE SWITCH, then have your mechanic replace the brake switch ?. $125 to look at it, is a " highway robbery " without doing NOTHING. Quote from your stealership 5-7 thousands without seeing the truck for diagnostic is another robbery. AMMCO may rebuild the whole transmission for 1/2 of that amount. Good luck.
I have a 2005 clk500 that I literally just purchased. I have another that got t-boned, so parts are at my disposal luckily. All of a sudden, CE light & ABS light were on and car wouldn't come out of park. Warnings included: Display malfunction, ESP malfunction & Break Wear. Had the shifter switched out the day after (yesterday), fine today, while I was driving this evening, all lights back on, car shifted to park fine, once in park, locked up again. Any ideas, proven solutions? I should mention brake lights are working fine NOW. It came off the carrier with multiple bulbs out, including both tails. Tail bulbs were good however, taking the circuit boards out magically corrected this problem the day before I started having this new problem. Could it still be the switch?
Old 03-07-2014, 01:36 PM
  #33
mohd.awaly's Avatar
mazda mx5
Just change the brake light switch man .. common mercedes benz problem
Old 03-13-2014, 07:40 PM
  #34
TONER-ISO-9001's Avatar
This is my first attempt at using this forum. So here goes. I have a 2001 e320 two wheel drive. The transmission stuck in park. Long story short, after much research that suggested replacing the brake switch and the multi-pin connector to the transmission and having he MB DEALER perform both operations. The transmission shifter was still stuck. Yes the pen trick unlocked the trans, discovered only after the fact. However, approx. one thousand dollars later, I have a new trans. shifter, multi pin connector and brake switch. Go figure: I brought in the car to the MB dealer due to a collapsed spring perch and the shifter=stuck in park only happened while there!? I did get MB corporate to pay for one half of the spring perch repair, due to citing their historic covering of this defect=$1400. Hope this helps you. Best...
Old 05-01-2015, 08:03 PM
  #35
fastvwtuning's Avatar
AUDI A4
Question STUCK IN PARK,NO BRAKE PEDAL SWITCH
WORKING ON A 2003 C320 COUPE,,,NOT BRAKE PEDAL SWITCH,,,STOP LIGHTS WORKING PERFECT,,SHIFT STUCK IN PARK
Old 01-16-2016, 02:34 PM
  #36
Mista Keith's Avatar
2001 e320 mercedes benz
Break light not working stuck in park
Hello my problem is my car is stuck in park break stop lights are also not working the pin trick works do you think it could be my break light switch
Old 01-16-2016, 03:00 PM
  #37
Correction break lights were not working and gear stuck in park well I put bulbs in break lights are now working but gear still stuck in park what might it be
Old 01-16-2016, 10:12 PM
  #38
In my experience, that is the most common, obvious and cheap fixes. Is replace it.
Old 01-16-2016, 10:45 PM
  #39
Go for the brake light switch, they go bad and everything is interconnected on these cars. If your brake lights are now functioning, then I'd imagine the car is recognizing that the brake is being depressed, so the switch may not be all the way bad, just faulty/going bad. If you get no where with the switch, the next thing you could look into, but don't replace it haphazardly, is the gear shift assembly itself. If everything is good there, you'd probably have to look at the esp module as being faulty or failing.
Old 04-21-2016, 08:05 PM
  #40
XHULIANO's Avatar
2013 MERCEDES ML350 BLUETEC, MERCEDES ML W163, MERCEDES W124,MERCEDES W205
IT HAPPEND TO ME 8 MONTHS AGO BUT MY FRIEND FIXED IT .
Old 06-23-2017, 02:50 AM
  #41
psjimm's Avatar
Owned 450 SL, 633csi, Miata, Honda Civic
Just fixed it by clicking one button
Let's see if I can add a jpg
This worked for my 2001 E320 with the ABS BAS ESP CHECK ENG VISIT WORKSHOP lights going..DON'T PUSH BRAKE PEDAL,
insert key, move to run position, (start eng) then just (gently and once only) push the top portion of the switch to the left of the red triangle.
Let car run for a few, five mins, then, if lights lit, turn off, remove key, insert key, start, sit and wait. Lights should not appear except, perhaps, the check engine light, although it went out for me and lights have not returned. You should now be able to shift normally, drive normally.. it's related to the auto spatial ya da ya da something or other.
Attached Thumbnails Stuck in PARK + BAS/ESP light....HELP!!!-dashbutt.jpg
Old 11-21-2019, 04:14 AM
  #42
Steven Manyasi's Avatar
C320
My C320 Gear stuck in Park + ESP/BAS/Stop Lamp Errors
Hi, my C320 gear has been stuck in Park + ESP/BAS/Stop Lamp, however with the manual override I can drive with no problem. I have tried looking for the brake light switch above brake pedal, I can only see the provision but no switch.
It's a 2002 model and would really appreciate assistance as to the location of the brake light switch if at all. Thanks in advance.
Old 11-21-2019, 09:34 AM
  #43
bartp1303's Avatar
S202 220CDI, S202 C43
No brake switch on yours. 2001 was the last year I believe.
Old 11-21-2019, 12:48 PM
  #44
C320
Thanks much for the information. Would you know what the issue would be and how to sort this please?
Old 11-21-2019, 12:59 PM
  #45
bartp1303's Avatar
No problem,
I am not a mechanic, but I have issue with my gearbox not going into gears. I've been reading a lot and collecting every piece of information I could find.
Do you have volt meter? put it on AC and test wheel speed sensors. you need to spin wheel while measuring and see if there is voltage increase.
I tested mine and they are good, but as soon as I unplugged first one my ABS/BAS/ESP lights came on.
Since yours are already on you will have to clear the codes anyway.
Good luck!
Bart
Old 11-21-2019, 01:19 PM
  #46
C320
Thanks much Bart, I will try that, however, I feel that it still doesn't address the gear stuck in park problem, unless I've missed something?
Old 11-21-2019, 01:31 PM
  #47
bartp1303's Avatar
It's all interconnected.
If you have faulty wheel sensor that will trigger error in ECU/TCU light up your dash error lights and disable gearbox to protect it.
Sometimes it goes to limp mode (last gear that worked before fault occurred. Sometimes it will disable gearbox all together (that happened on mine)
Hope you can sort it out.
Old 01-01-2021, 12:23 PM
  #48
Tdml350's Avatar
ML350
Same issue for 2003 ML350
QUOTE=PHML;3562527]Guys,
I need your help.
My gearbox is stuck in PARK.....also BAS/ESP light was on. Had the ML320 towed to a shop....and left it there.
Any ideas what's causing it to stay in PARK? This might be a protective mechanism like Limp Mode imo.
Thanks in advance.
Pete[/QUOTE]
Once light come on the car will not leave park without turning the car off and back on which will turn the ESP light off. My 2003 does not have the switch attached to the brake pedal that is recommended to change. What will fix this?
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: Stuck in PARK + BAS/ESP light....HELP!!!
