ESP 2001 C320
C320 2001 MERCEDES
ESP 2001 C320
#1 WHERE IS THE TROTTLE/PEDAL SENSOR SWITCH B LOCATED.
#2 ESP WARNING CAME ON WHILE I WAS TRUNING RIGHT AND THE CAR DIED TURN THE KEY OFF, THEN TRUN THE CAR BACK ON AND STARTED AND WAS ABLE TO GO ON DOWN THE ROAD.
JUST BEFORE I GOT HOME I WAS TRUNIMG RIGHT AGAIN THE CAR DIED AGIAN., TRUN THE KEY TO OFF POSITION THEN BACK ON ABLE TO GO AGAIN.
COULD BE STEERING ANGLE SENSOR,BRAKE LIGHT SWITCH.ECT.
ASKING ABOUT THE TROTTLE SENSOR WHEN YOU GIVE IT GAS , IT WILL LAG A VEW SECONDS.
HAS ANY ONE HAD THE PROBLEM?
ANY HELP THANKS
ANY HELP THANKS
Caps are annoying...
The TPS is usually next to the brake booster. Have a friend step on the pedal with engine off and look for what moves.
I doubt any of the other sensors mentioned would cause it to stall.
The steering angle is reset by turning the wheel lock to lock.
