Help reset EC light
Help reset EC light
97 SL5OO with single zone a/c. Put in new condensor and recharged, but EC light stays on. Ref. temp switch OK, and if you hold EC button with engine running it will go out and the a/c will start. But it comes back on again when next starting engine.
Canit be done on the panel, or does it need a special diag. tool?
1 Post
1997 Toyota Tacoma 4x4
Re: Help reset EC light
Thanks MBtech208. I had a stone go through the condensor and the EC light came on same time, so replaced with a new drier. Charged with 950gramms and 60ml pag.
If I hold the EC switch for 10 secs and it goes out, compressor starts and runs, and low side pipes get cold, until I switch engine off again.
From a tech disc I got the following: To clear DTC fault codes, switch ignition on, within 10 secs press recirc/REST/temp arrow up at the same time for 2-4 secs, then diplay should show --- . But this doesn't do anything. I spoke with MB, but they just said put it on the Star, but they always say that!
