97 SL320 starts and dies, starts and dies
If you are a professional MB mechanic, I look forward to your input. I've discussed this problem with some of the best in the profession to no avail. Here's a list of facts.
No codes (checked with snap-on, Baum, SDS)
Fuel pressure in specs
Delivers more than liter in 40 seconds
Grounds and power to Engine Control Module checked
No problems indicated with DAS
Tried all 3 keys including valet
CPS replaced with new unit just for s*its and giggles
Same symptoms when fuel pump made to run with Snap-On scanner
Yr model too early for rusty flywheel
Car runs on carb cleaner
While running on carb cleaner no MIL and attached noid light flashes but appears dim
UPDATE: latest checks
Unplugged MAF no change
Shorted engine coolant temp
Smoked the intake
This one is kicking my butt.
Thanks in advance for any new light, because I'm running out of straws.
Have you had the fuel pressure gauge on while the car was running?
If fuel pressure ok, I would also check fuel injector spray.
Hope this helps.
My observation in all this is that the ECMs must store some deep memory that died during the week the unit was out of the car. Even though the MAF was defective, it wasn't shutting down the car, because unplugging it made no difference. It was the computer protecting the car like HAL. Remember HAL? I can now unplug the MAF and the car still runs, which is normal. I don't like to demonstrate that too often, because I gotta go back in and clear MAF sensor and throttle position implausible codes. A suggestion to you fellow MB mechanics who read this; this is one of those few times it is ok to throw a part at a car. I hope this benifits someone.
