NEED HELP URGENTLY!!ABS/BAS/ESP WARNING LIGHTS & WITH SHIFTER STUCK ON PARK, THANKS
I have done some research on the forum, and says its the brake switch need to be replaced. So I went to the local mercedes stealer to buy the brake switch for our car. But i was told by the part dept. The CLK doesnt have the brake switch and it uses pressure switch and cost about $140. Since i am still don't know what the problem is, So i decided to come back to do some more research and ask people from this forum.
Please help as I really don't want to spend too much to get this sorted out. could it be the pressure switch?Also, is there a unlock shifter hole in our CLK,?so at least I can drive it to the shop Anyone else with this problem and what was the end result? Please kindly advise, Thank
