MCS Radio no sound/no cd changer found 03ML350
Old Oct 13, 2009 | 10:36 PM
Driver55er's Avatar
w210 e55
I did a search but found nothing on this. My 03 ml 350 MCS just stopped working all of a sudden. No other issues other than no sound and a no cd player found error. The cd player ejects the cartrige etc but the head unit won't recognize it. I've tried pulling the fuse and also disconnecting the battery cable. Both with no luck. Any help? Thanks. Is there a common area for the fiber optic cable to get pinched?
2003 ML350 no navigation
Old Oct 21, 2009 | 06:03 PM
Driver55er's Avatar
w210 e55
Found this great link that helped me diagnose my system and thought I would share it:
http://www.carstereohelp.com/mercedesFiberOptic.htm
Old Jul 5, 2012 | 09:10 AM
dceglenski's Avatar
ML350
Same problem
Did you find a fix?
Old Jul 5, 2012 | 10:08 AM
Driver55er's Avatar
w210 e55
Optical output on head unit went bad. Only fix is thru a company on the east coast that fixed factory Alpine radios. Cost 250 worked perfectly ever since.
If your head unit work but you don't get sound. You need the special radio removal tools to pull head unit 2 bucks on ebay if you don't have them.
Then unplug the fiber optic cable and turn on radio. If it doesn't flash red out of the fiber optic plug or flash red on the cable side you have a problem. The whole system, HU, amp, cd player, and Teleaid unit are all connected in series via a fiber optic cable. Unplug one at a time and look at both ends to see where there is no red signal flash.
Good Luck
PS dealer told me it would be $4000 to fix ...bunch of jags!
Old Jul 5, 2012 | 05:32 PM
biker349's Avatar
cl600
hi, where did you send the radio for repair?
Old Jul 5, 2012 | 07:26 PM
Driver55er's Avatar
w210 e55
The place that fixed my head unit is:
United Radio
5705 enterprise parkway
east syracuse, ny 13057
800-448-0944
www.unitedradio.com
Regpalce cpu component in logic circuit
rebuild intermittent regulator circiut assembly
250.00
Good luck
