Looking for used engine for 350SDL
Old Mar 3, 2003 | 01:20 PM
drapp's Avatar
1991 350SDL
Does any body knows where can I get used engine for 1991 mercedes 350SDL?
Old Mar 3, 2003 | 08:38 PM
via500's Avatar
You don't want a used 350SDL engine unless it has had the new design cylinder head installed. I'd fix yours unless you drove it too long broken.
Old Mar 4, 2003 | 07:48 AM
drapp's Avatar
1991 350SDL
Why not buy a used one, if compression is checked, and low miles? what would it cost to fix mine? where are you located?
Old Mar 4, 2003 | 07:53 PM
via500's Avatar
Because original 350SDL engines sooner or later (mostly sooner) cracked their cylinder heads - the engine belonged on a Yugo! The new replacement head that has been released is supposed to have fixed the problem - that's the way to go unless you can be sure the used engine already has the new head. But like I said if you drove yours too long broken it will need more than a new head.
Old Mar 5, 2003 | 08:22 AM
drapp's Avatar
1991 350SDL
You mentioned you might be able to fix my engine, are you a mechanic, and how much would it cost? where are you located?
Old Mar 5, 2003 | 08:59 PM
via500's Avatar
http://mail.mercedesmailinglist.com/...tinfo/mercedes
Ask around on this list - there are diesel people there that can help
