AIr filter in 08 S550
08 S550, 08 E63
Is there an easier way to remove the cover to replace the air filters or do I have to do an upsidedown unscrewing?
Thanks!
Thanks!
pull the front section off first, then just undo the metal bracket on the rear of air cleaner ,push it to the rear ,and undo the air ram tubes ,then pull the whole air cleaner housing straight up of the air mass ,turn it over and use a torx 20 to undo the 4 screws per side ,change filters ,then when putting it back on make sure it is all the way down and the secondary air pump line is put back on ,
