undervoltage
Old Mar 3, 2010 | 03:54 PM
sugarandrea36's Avatar
C230
undervoltage
I was driving my car yesterday and "undervoltage consumer defective" came up on the screen. What does that mean? What do I need to do? Can I still drive the car? It won't cut out on me will it? Help
Old Mar 4, 2010 | 09:13 AM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
Welcome -
MB cars require a certain minimum battery voltage for all the electronics to function correctly. At some point if there is insufficient voltage, the car will not start even though you have headlights, etc. The error could be because the battery is weak or the alternator is not providing enough charging amperage to the battery. It could also be something more sophisticated with those issues as the symptoms.
Have your alternator and your battery checked by a competent MB mechanic -- indy or dealer as soon as possible.
Depending on the problem it could leave you stranded unexpectedly. That's the reason for the error message -- to warn you.
Good luck.
