MB Tech Help w208 climate & BAS/ESP
This is what I've done to try to resolve the BAS/ESP:
1) Checked the battery (has good charge)
2) Replaced the Stop Lamp switch today
3) Checked every single fuse ( all are good )
4) Disconnected the battery, tried to reset the BAS/ESP, climate, windows, sunroof, etc....
5) Plugged an OBD2 scanner and no codes
6) Last year or a year before, I switched out the voltage regulator on the alternator which should still be good. OEM part. Same with brake pads and sensors.
Last night my interior lights stopped working but found out I had a broken wire
on the bulb on top of the ciggarette lighter. Two grey wires were falling of the electrical tape previous owner tampered with? but fixed that and lights are working again.
Hoping it's not a major repair. Please let me know if I should try something or if you know what the problem is.
Thank you,
Billy
edit: this is on a 1999 CLK430
Jeff
