Strange behavior from 300D
Old Apr 1, 2010 | 03:51 PM
XLR8R22's Avatar
'78 300D, more to come soon!
Recently I took my 78 300D on a short road trip, about 110 miles to go camping with some friends. On the return trip, about the last 30 miles, i noticed the temperature had risen to about 190-200F, not red lined, but hotter than normal. A quick visual check showed no obvious problems, good fluid levels, and no leaks, smoke, or bad smells. I initially suspected the thermostat, drilled a few small holes and saw a slight improvement, so i replaced it all together right before embarking on a much longer road trip (about 350 miles). It made the trip fine, but still ran hot, around the same temperatures as before. Near the end of the trip there, i noticed a slight hesitation at freeway speeds, it seemed random, and only noticable above 60, almost like some additional parasitic drag on the engine. There were no strange noises or other engine problems. The next morning I noticed a small puddle of coolant under the oil pan, but it only looked like it had been dripping for an hour or so, and it appeared at first to be coming from behind the crank pulley, but closer inspection revealed (at least I think) that it was coming from the water pump. Also, the leak stopped the moment I started the engine. There is no coolant in the oil or vice-versa, and I don't believe it's an internal engine problem, although... ?? Anyway, I'm set to replace a water pump, but thought I'd ask before I waste time and money fixing something that isn't the problem.
