'99 E-Class starting problem
Old Mar 29, 2003 | 09:19 AM
Corp DL's Avatar
C230 Kompressor Sport
Question '99 E-Class starting problem
My '99 E430 has recently developed a ignition problem. Obviously everything is electronically controlled so I'm thinking it may be an electronic issue.
When turing the key to start the car only sometimes does it start a bit then just not turn over. Kind of like it "coughs" just once. So, all I do is either turn the key back to position 1 and restart and it's fine OR I just hold the key in position 3 after it "coughs" and then it will start as normal after about a 2 second interlude.
Though I have not tested my battery strength with a meter, the battery seems to be fine. I've really done no other diagnostics tests and thought I'd post this question to see if anyone has had a similar experience.
Any info is appreciated.
Old Mar 29, 2003 | 09:54 AM
f4i 954's Avatar
2009 e class 2012 ml350
starting
This is only mi opinion.
You need to remove the starter motor & apply (MB grease) on the fly wheel.
A new starter will also fix your problem, but ther is no need for that.
Old Mar 30, 2003 | 03:19 AM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
You probably have a bad key. Try the second key, or the valet key and see if it still acts up. If it does, you either have a problem in the EIS (ignition switch) or a bad crankshaft position sensor.
Old Mar 30, 2003 | 04:52 AM
Marky's Avatar
AMG
f4i 954 is having the answer! I had the exact problem on my 99 E55. Contact your dealer and have them do the work.
Old Mar 30, 2003 | 07:30 AM
patrick's Avatar
The problem is "known" at MB.
This is indeed the way to fix it:
