Transmission Question
E260
Please help guy's!
I rebuilt the transmission on my 1987 E260 (722.4) and have since re-installed it and it smokes real BAD. It's white smoke and for sure tranny fluid. It did this same thing just before I burnt the original transmission up.
What would cause it to be burning transmission fluid?
How can I fix it?
Thank you much,
Tony M
How can I fix it?
Thank you much,
Tony M
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
The oil is being sucked up the vacuum line from the modulator valve into the intake manifold. disconnect the hose from the transmission to be sure. You will need a new modulator. Easy fix and a common problem.
