Squeaking/flexing window after replacement
Old Jun 3, 2010 | 02:02 PM
BenzOwner's Avatar
2013 ML350 BLUETEC/2012 SLK350/2000 C280/1972 28SE
I recently replaced the windshield on my 2007 ML320CDI for the third time (thank you I-5). In the past I haven't had a problem with the replacement however this time I'm having nothing but problems.
Now the window is squeaking with every little bit of body flex and it sounds as if the glass itself is flexing. Additionally, there is a significant amount of wind noise at speeds over 55-60mph. The dealer's glass company changed the glass yet again and the problem seems even worse. I watched them change the glass and it seemed to fit in perfectly. There was a bit of residue left over from the previous installations around the opening and the bead of sealant used was supposedly the recommended amount. Every time the glass was replaced it was replaced with OEM glass.
The glass company and I are both at our wits end. Has anyone has a similar problem? Does anyone has any ideas.
Thanks.
Glenn
