ERROR P0702
Old Aug 12, 2010 | 09:49 PM
blackm3talhindu's Avatar
'02 C230k coupe OB
ERROR P0702
HELP! My 2002 c230 coupe is stuck in "limp home" mode and the only error code is P0702. I know it is a transmission code (maybe im wrong?) but the connectors that I could see are just a little wet? If anyone can help point me in the right direction it would be much appreciated!
Old Aug 13, 2010 | 10:14 AM
paulv's Avatar
03 E320 -wife's car now; 07 Porsche Boxster S - my toy
You're right in that it is a transmission code. Check the voltage at the "wet" connector as it should be close to battery voltage. Since it's wet, it may be shorting out to a point where the voltage would be reduced. Good luck.
Regards,
paul...
Old Aug 15, 2010 | 12:23 PM
waybomb's Avatar
SL600 r230, SL600 r129, SL500 r230, ML320, C280 Sport, R170 450SL, 190e 2.3 16V (2)
Here's a link to a table of codes:
http://www.bba-reman.com/content.asp...on_fault_codes
