Help! SL600. ASR light on, limp mode $12k to fix!!!
My co-worker 's SL600 (R129) ASR light keep lighting up and the car is now on limp mode and barely can drive it. Dealer wants $12,000 to fix!!! anybody know what's wrong? $12k to repair is ridiculous.
the car has about 60k miles on it.
what was the estimate for? If it needs a hydraulic unit or a combination of things it may be that much. Possibly a problem with the hydraulic suspension. let us know what exactly the dealer wants to replace.
2003 c230k magma, c5, c7, 6 spd.
i believe that many of the repairs on the 12 cylinder and 8 cylinder of the same year and model are pretty much the same, except for things like extra spark plugs, a different coil and post 2003 turbo chargers. correct me if i'm wrong. oh, and maybe the brakes are upgraded.
if the car is old enough, pre 2005, I have Carsoft available, and I live in socal also, so I would be willing to help you out with the codes, 2 years ago my C320 also went into limp home mode, but I replaced the transmission our selfs, saves a whole lot of $$$.
Yeah its the Electronic Throttle Acutator. very common problem on the 600 you will need two of them/
But it can be fixed for under $1000. Some ETA can be rewired. The problem is they used biodegradable wiring insulation and its causing problems
google search for ETA mercedes
