high idle
1988 420sel mercedes benz
high idle
I have 1988 420sel with high idle.I cleaned the idle control valve looked good still high. I then replaced the idle control unit still high. NEED HELP THANKS
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Have you checked the fuse on the overvoltage protection relay? It may be blown or the relay may be faulty, common cause of high idling/poor starting. check in the W126 forum for more info
I had the same problem and replaced many parts before finding the cause. It was a box (1x1x4) near the firewall with multiple pin connectors that was easy to take out and replace by simply plugging in the new part. I can not recall what the mechanic called it but it helps to define idle and fuel distribution.
