DIY transmission swap; can I drive to dealer for DAS relearn?
Old Feb 1, 2011 | 01:17 PM
MountainStone's Avatar
02 C32
It looks like I will swapping a rebuilt transmission into my '02 C32 (W203). I am told the mechanical procedure is straightforward but I will need to have the DAS computer connected to my car to perform a relearn/adaptation so the new tranny will play nice. If so, can I drive the car 20 miles to my dealer or do I need to tow it from my shop so as not to damage the new transmission? Thanx!
Old Feb 2, 2011 | 02:19 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
It should work fine straight away, it's better to get it reset at a dealer but you can just drive it gently at it will relearn slowly. It'll be fine to drive it to the dealer.
Old Feb 3, 2011 | 07:04 PM
02 C32
Really? Sweet! I was afraid I would be stuck in 'limp-mode' or something. Thanks for the response!
Old Feb 3, 2011 | 10:37 PM
Ausmbtech's Avatar
it'll only be in limp mode if something is wrong or there were codes before the swap. make sure you flush the transcooler and lines if you're changing the transmission, if you dont have a record of a radiator change then get a new one as it's the number 1 cause of transmission failure in C32's
Old Feb 5, 2011 | 05:11 PM
02 C32
Thanks again. I am changing this transmission because it was destroyed by glycol contamination; I have already changed the radiator. I will definitely flush the cooler and lines before connecting them. Thanx again!
