power liftgate adjustment
Old Feb 24, 2011 | 09:28 AM
MAGGIE B's Avatar
glk
Unhappy power liftgate adjustment
my power liftgate hits the roof of my garage when it is open. there is supposed to be a height adjustment for it in the onboard computer but i can't find it. can you help?
Old Feb 24, 2011 | 02:37 PM
j21importer's Avatar
07 E63, 04 discovery
go through the vehicle settings on the intsrument cluster and you should be able to change it there.
Old Feb 24, 2011 | 04:03 PM
MAGGIE B's Avatar
glk
i cannot find the vehicle settings on the instrument cluster??? maybe just really dumb but nothing comes up that says that.
Old Feb 24, 2011 | 04:14 PM
i will see if i could try this out on a glk and give you instructions on how to do it. If you have your owners manual you may be able to do it by holding the tailgate button down at the level you want it to open to.
Old Feb 24, 2011 | 04:40 PM
MAGGIE B's Avatar
glk
thank you very much. sometimes it will stop and stay when you hold it, sometimes it sounds like you are making it grind something inside. i am not always at the back when it gets opened so it has hit the ceiling a few times ):
Old Feb 24, 2011 | 10:46 PM
I checked and you should be able to open it to where you would like it to open. Then you hit the close tailgate button and hold it until an audible noise is heard.Close it and then it should open back up to that position you set it too.
Old Feb 25, 2011 | 09:18 AM
MAGGIE B's Avatar
glk
You have to use the buton on the bottom of the door, and works like a charm!!!!!! thank you so much!!!!!!!!!!!!!!!!
