Error Codes+ Stereo not working+ Batt. Dying?
Just a few days before the batteries were dying the radio stopped functioning. The radio console powers on, but no sound is outputted, also it says "No CD Changer". After further investigation I looked in the trunk and made sure that the fiber optic cable was plugged in. I also disconnected the bundle of cables all on one connector on the amplifier and made sure that it was receiving +14.x volts on the thick gauge red and black wires.
One thing I am worried about is that the pins on the amplifier seem to have some buildup of a hard green substance on it which looks like zinc/lime/calcium. I haven't got around to cleaning it, but I suspect that this is interrupting the electrical circuits of the amplifier, and yes the fuse is good .
Also there is an problem with the front right seat control? What happens is the lights, light under the passenger door, blinks almost like a code. On the front right, sometimes the window seems to have a "glitch" where if lowered or raised it will randomly stop , the same goes for the right view mirror.
I also scanned my car with Carsoft MB 7.42 and got the following codes on the first scan:
DCM-FL:
B1010 (Power supply: tension low)
B1011 (Power supply: tension high)
B1205 (Exterior mirror front left: mirror heating)
B1303
B1501 (Right: front door power window switch faulty)
B1502 (Right: front door power window switch faulty)
B1504 (Right: rear door power window switch faulty)
DCM-FR:
B10F3
DCM-RR:
B1000 (DCM Rear Right Faulty)
H1004 (Rear Right DCM control unit faulty)
B1010 (Power Supply: under voltage)
B1011 (Power Supply: over voltage)
H1101 (Rear Right DCM control unit: windows relays does not switches)
H1103 (Rear Right door engine(power window): Hall sensors power supply)
H1104 (Rear Right door engine(power window): Hall sensors)
B1504
D2B *Stereo*:
B1088 (CAN communication error with KI control unit)
N1112 (NO data transfer between D2B master and D2B processor possible)
B1146
N1111 (No data transfer between D2B master and D2B component possible. The component at location 0 reports a fault in the D2B ring.)
After scanning all of the codes I erased all of the codes turned the car off then started it, and rescanned. The following codes came up on scan 2:
DCM-FL:
B1303
DCM-FR:
B10F3
D2B:
Also battery drain stops if I unplug the amplifier. Also the stereo says "no cd changer", but I checked an made sure the power plug plus the optics cable was connected to it
Also there are 2 black boxes under the front passenger seat, which is supposed to control the door? I have also unplugged this because of abnormal battery drain. If I leave it plugged in, the battery dies over night which is about 10 hrs over night as I drive my car every day to school at 6:30 AM
Any thoughts and suggestions would be much appreciated.
