W202 Rear Subframe: Frame Repair Question. body shop frame report
Old May 6, 2011 | 12:20 PM
Yokohama's Avatar
190D
An acquaintance of mine has had several incidents that have damaged his W202 C230. The last incident has damaged the main control arm mount on the rear subframe. The body shop has indicated that the body would need to be straightened before the new subframe would mount.
I need to know if the new subframe will fit and get the car mobile again. I understand that the body shop wants to repair the whole thing, but it just needs to be mobile at this time.
The photo is of the report from the body shop:
Old May 31, 2011 | 06:54 PM
u001elg's Avatar
2006 ml350
I bet with enough persuasion the new rear sub-frame could be bent to fit, but to what purpose? I would just stick with the existing crashed sub-frame and use a car dolly to move the vehicle to get it "mobile".
Even if you could get the sub-frame to fit (which it shouldn't without modification) you will not have enough adjustment to set the alignment.
If you are going to put it on the road then... Bite the bullet and get it straightened. If the car is that marginal to you that you don't want to spend the money, then just cut your losses and scrap the car now.
Old Oct 19, 2011 | 04:38 PM
JCD1962's Avatar
2000 C230K, 1929 Ford P.U., 1946 Pontiac
Don't worry about that body diagram, that's just specs. for the frame machine and the body man. There's 2hrs. tear down, 2hrs. set-up and 6 hours pull time, though it will only take a good bodyman about 6 hours, They will get the damaged area with in specs. to mount the new part, then it will need a rear alignment. I was in the business 25 years. Let them do the job if your going to keep the car.
Old Oct 23, 2011 | 01:39 PM
KENNY94945's Avatar
You have options above.
I do not fully understand your needs.
Perhaps what the body shop is saying is that the body panels and wheel houses needed to be pulled out of the way and aligned (or pulled and removed) so the new subframe can be installed.
Pulling the wheel house et al before removal may help save those parts instead of having to purchase replacement parts.
Crashing sucks and specialized tools (and a work garage) are sometimes needed to repair...even repairing 1/2 way.
Again, I do not fully understand your inquiry.
Old Oct 23, 2011 | 07:06 PM
JCD1962's Avatar
That's exactly what they are saying, pull and align the body before replacing the sub-frame, as long as it's within 1/16 to 1/8 your good, then they can bolt up the replacement parts. Used or New it won't matter, that's a gravy job, all day long... :-)
