control arm replacement
Old May 15, 2011 | 07:46 PM
maxlanctot's Avatar
c230 2006
I need to replace the lower control arm on my 2006 C230. Will I need to do a wheel alignment after? any other tips?
Old May 15, 2011 | 08:38 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
I have the maintenance DVD - I should be able to print out the instructions for you. Pretty sure that you won't need an alignment.
Old May 15, 2011 | 10:36 PM
maxlanctot's Avatar
c230 2006
thanks, looking forward to it...
Old May 16, 2011 | 06:24 PM
Gullwing's Avatar
1987 190E 2.3
Why does it need to be replaced, if you hit something then yes you should have an alignment
Old May 17, 2011 | 07:07 AM
maxlanctot's Avatar
c230 2006
The ball joint is loose on the driver's side lower contral arm.
Old May 19, 2011 | 01:04 AM
tri-star tech's Avatar
Top Answer: 1
2004 CLK55
Yeah you need an alignment
