Replacing the primary refrigerant pressure sensor – 2002 E320
Old May 25, 2011 | 03:27 PM
toddlaroche's Avatar
2002 E320 4Matic
Unhappy Replacing the primary refrigerant pressure sensor – 2002 E320
Can someone tell me the procedure for replacing the primary refrigerant pressure sensor in my 2002 E320?
Thanks for any help...
Old Jun 15, 2011 | 11:35 PM
amg305's Avatar
2009 E350
The a/c system must have the refrigerant recovered by a machine (illegal to vent out to atmosphere) then you can open the system and change any part. Compressor , evaporator and even pressure senor. After replacing the sensor . Change the drier also(optional) I recommend you add some a/c dye to detect future a.c leaks. pull a vacuum on system . and charge it to specs. Usually located on the engine bay area on right side covers . around 2lbs if had to guess.
