CAN communication failure to engine control module
Old Jun 29, 2011 | 10:07 PM
Ali Daei's Avatar
97 C280
car stopped running and I get this code.
any help is greatly appreciated
Edit: this is for a 97 c280
Old Jun 30, 2011 | 01:37 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
That code can be stored intermitantly and is usuall irrelivant. If the engine stalled whilst driving and could be restarted for at least 5 mins and it the the V6 model (not the inline 6) then it's most likely to be a failed crank angle sensor (CPS). This won't leave a fault code.
If the symptons are different then let us know what occured when the engine stopped.
Old Jul 7, 2011 | 05:25 PM
Ali Daei's Avatar
97 C280
hey sorry for the latee reply. ok so pretty much before the the car stopped running, its was driving perfectly, no check engine light nothing. i got home I changed the battery in the key fob and after that it didnt start. I thought the key wasnt synced so I followed the manuals directions and and synced and nothing. I checked the valve on the fuel rail to see if i had a bad fuel pump or relay but gas was shooting out of the valve. also checked spark and that was good.
that same day I went to pep boys to grab some starter fluid, it turned on , made some clanking noise and a cloud of smoke was shooting out of the exhaust. and shut off.
following day I had it towed to a mechanic they hooked up the computer and thats what came up.
can communication failure to engine control module .
Old Jul 9, 2011 | 08:18 PM
Ali Daei's Avatar
97 C280
bump!!1
Old Jul 12, 2011 | 03:44 PM
Ali Daei's Avatar
97 C280
Bump
Old Jul 13, 2011 | 11:00 PM
Ali Daei's Avatar
97 C280
ok so I changed the crank angle sensor or position sensor and saame thing, turns over but doesnt start.
I forgot to add, when i changed the batteries on the key fob I thought the battery was dead so I went bought new batteries ,still didnt work but I didnt make anything of it. I opened it up and theirs this metal piece where the batteries sit on, my finger hit it and it got loose.
the weird thing is, when I try to start the car the lights on the rear view mirror. dont go off
Old Jul 18, 2011 | 11:39 PM
Ali Daei's Avatar
97 C280
wow still no replies?
moderated by an mb tech?
