Rough starting and running?
The problem seems to be state wide.Local Tv had a story on it.
http://abclocal.go.com/wabc/story?se...rticle-8193935
My buddy said the major brand affected was Sunoco and all the people who had the problems used this gas. When I Went to PA over Memorial Day, the best brand I could find near New Hope PA was Sunoco, half tank of 91 and this is when my problems started. Engine chugged, hard start, etc.
I got a check engine light, code for misfire bank 3, switched coil packs with 1, the wires are different, swapped wires as required, checked a random (new) plug as fine, buttoned everything up . Better but not great so i Dumped Techron in the tank, filled up with Shell93 and repeated same. Now car purrs!
If your MB or AMG is having problems starting chugging misfiring and so on look to the gas line and system. How many spark, fuel, and other systems may have been compromised or unnecessarily replaced? May I suggest starting with bad gas therapy first, then do some component swapping, and replace expensive components last?
