General Maint...
My question is; will I be able to do general maintenance on this car or do I need to bring it to the shop for things like oil changes, etc…etc…
Thanks,
BenzMan1
My Porsche was really quaky. My fuel regulator was fused through my dome light and the light bulb it self was the junction for the circuit. I found this out the hard way, I was changing the bulb out at the local auto parts shop and the car would not start so I had it towed home. When I started researching the symptom I was @iss3d to know that all I had to do was out the light back in...What is the OBD II that you mentioned? Where can I get one?
Does any one know where I can get a set of shop books for my car? I have a Hanes put I would like the real deal.
I have notices in the tech section that people use a type of suction canister for oil changes is this necessary?
Try http://www.alldatadiy.com/ for a model specific annual subscription.
For a more expensive service direct from MB at http://www.startekinfo.com/StarTek/
Startek wil allow you to purchase access for only one day for $20 if you have a specific project.
So far I haven't tried either, but have read good reports on alldatadiy.com.
The tester can also delete/turn off error codes like "Check Engine"
light.
