ECU Tuning Options (Siemens ME2.8)
So my questions:
- Are there any free or really cheap programs that can get the job done (ECU tune)?
- Does each program require its own multiplexer (reader)? I noticed Carsoft has its own multiplexer and software...not sure if you can use a different reader and get the same results.
So my questions:
More information about tuning for this platform can be found here: OE Tuning C43, 4.3L V8 ECU Tuning
I want do the same you did: C36 engine + tranny into my 124 E320. Now I am really inspired by your work using all the W202-OEM-parts like modules & wiring. My thougths are the same: seperate all the unnecessary stuff from w202's wiring harness.
But my donor C36 has ASR traction control. Here are my major doubts:
-ASR traction control system very similar to normal ABS, differences: wheel speed sensors for both rear wheels instead of single sensor mounted in diff housing - no problem, swap to w202 ASR rear wheel knuckles, they should perfectly fit into w124 axle.
-ASR/ABS pump uses 6 brake lines - no problem, add a second rear brake line
-ASR system uses both front wheel sensors or all wheel sensors for vehicle speed data - Problem when using w202 front abs sensors on w124 wheel knuckle. Does they fit? How did you solve it?
-w202 Tachometer/instrument cluster is different - did you get all important wires from the w202-wiring into the w124 instrument cluster?
Rest should be easy work, it's not my first m104 swap but the first using other platform's wiring and modules.
I hope to hear from you.
Best Regards, Max from Germany
In order to do this, you have to get ac compressor bracket from the W124 E320, dont use the w202 bracket.
