2000 C280 A/C not cooling
Old Feb 3, 2012 | 07:50 AM
vinceC's Avatar
2014 ML350 4Matic
2000 C280. No cooling effect. Pushbutton Module diagnostics shows compressor discharge pressure (#07) of 6.6 bar and temps around ambient on #03 (heater core) and #05 (evap temp).
I put my gauges on the system and I get a high side pressure of around 8 bar at idle rpm and at 3000 rpm.
On the low side I get about 6.8 bar at idle and when I raise the engine rpm to 3000 the low side pressure drops slowly to around 4.5 bar. Also, the low side pressure randomly bounces around a bit.
Both the suction lines and the compressor discharge piping is at ambient temp.
I suspect the compressor is the problem. Can anyone conform or suggest further tests?
Old Feb 5, 2012 | 11:18 AM
Dan Morgan's Avatar
97 S420
Your compressor does sound suspect, since you are getting some pressure change but your lines are not hot/cold. Good luck with it, I just had mine replaced last summer.
