m111.955 200c SC error code p2039
Old Apr 22, 2012 | 05:01 AM
yarza's Avatar
c200 kompressor
Hi!
My w203 started to loose power. Feels like supercharger is out.
I read error codes and there came up p2039 - powertrain - reductant injection air pressure sensor circuit low input.
Does anyone has idea where should i startfix the problem... If i erase the codes, the car will go just like before the error. Few days and then the supercharger "stops".
Thanks for answers!
Old Jun 6, 2012 | 05:10 AM
yarza's Avatar
c200 kompressor
Thanks for your answer. it was really helpfull and now i have fixed the problem.
Old Feb 1, 2013 | 11:08 AM
sdlopez83's Avatar
2002 C230 k
if you used common sense when posting people would actually see this. I have the same problem btw. But you posted this 7 months ago.
Old Jan 15, 2015 | 03:15 AM
Wadihm89's Avatar
C230 Kompressor 2002
Low Power - c230 kompressor - P2039
Hello I have the same problem could you please guide me through the solution for it
Regards
Old Nov 18, 2017 | 05:52 AM
Eyad,agheel's Avatar
W203 coupe 2.0 kompressor
Hi there
recently I came across the same code P2039 ,can someone guide me through the problem and how to fix it ?
Old Aug 6, 2018 | 08:24 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Just an FYI- I replaced the recirculating air valve and forgot to reconnect a hose that connects to the
oil catch thingy that sits on top of the SC (and also the recirc air valve is attached to) and it threw this code.
So, perhaps check your hoses in and around the valve cover.
