w211 a/c issue
Old Jun 2, 2012 | 03:52 PM
hooligan's Avatar
E500 2004
w211 a/c issue
wont get real chilly/
man it just wont blow cold air and it smells funky..kinda chemical smell. and as soon as i turn the ac on the cooling fan kicks in and blows like a **** non stop what can we check or service without star? my local import shops wants 100 bucks just to look at my rig.
oh and another thing i see none of the usual dripping under the car when running the ac like you do on most cars is that normal has anyone ever had anyone but a place with star look at their ac before im considering having the refig coolant checked to see if its just low
just took out the climate controls and i notice that i get a better flow of air from the driver side vents than the pass side. and when i try to use the controls to change where the air goes nothing happens..lame
any info would be great ill be trying to take it in for a check on monday and would like to know if there is anything i might point them to or have them do in star while its plugged in to make things better.
Old Jun 3, 2012 | 04:09 PM
kered's Avatar
C300
Shouldn't need a star to check the a/c system. You have probably developed a leak cause the freon to be low. Any decent shop should be able to evacuate the system to see how much refrigerant was left, put a vacuum on the system and leak tested and then recharge it. Most shops will add a dye to find the leak and have you return a couple of days later to pinpoint where the leak is coming from.
