Access to the Console in the E420
In both cases, I don't know how to access the inside of the console. Can anyone advise me? I already removed the handset - I just need to pull the radio and put the plastic glovebox back in.
1) remove the rectangular plastic shift frame
2) pop up the wood console by placing your fingers at the front edge of the wood behind the cigarette lighter compartment.
3) you will see 2 screws for the cigarette compartment. Unscrew these screws you can remove the whole compartment but don't forget to unplug the power for the cigarette lighter.
Use the MB radio keys to remove the radio. After you do so, put your hand into the opening and you will find a lever. Push on this lever to release the glove compartment or the phone module. Good luck.
JohnAMG
Where is the fuse for the Cigarette lighter? I checked both fuse area's and neither indicates the Cigarette lighter fuse. Furthermore, nothing else is failing to get power. The Radio and all lights work fine.
Just in case it's a connection problem, do you know where the Lighter cable connects on the other side? I checked the connection under the ashtray and it looks fine, although that little light isn't lit!
Thanks again, JohnAMG
JohnAMG
