c280 operating temp
Old Jul 12, 2003 | 05:05 AM
SLCPUNK's Avatar
c280 operating temp
I drive up a big canyon to work everyday. Today it was 100 degrees out, and I had the ac on the '3' setting. The altitude change is from 4500 to 8000 ft. The temp gauge crept up high, about half way between 100-and the max. Fan was on, thermo was changed couple months ago, and once I was over the hill it dropped back down around 97-100. Does this seem normal? I never saw it creep up that high and it freaked me out. The temp did go back down after I topped the hill. This is the first summer going up the hill, didn't do it last week when it was cooler.
I need to change the oil to 20-50, it's only got 10-40 in it now. Could that affect the temp when it's that hot out?
Seemed like it should have been a tad cooler, but under the circumstances do you think this is normal? Thanks.
1994 c280
Old Jul 12, 2003 | 12:07 PM
Nektopoli's Avatar
W203 & W204 3.0L 4matics & MR2 Supercharger
My roommates 98 C280(V6) never get's higher then about 83'(Were at 300ASL here), what speeds were you driving at?
NP
Old Jul 12, 2003 | 01:57 PM
SLCPUNK's Avatar
Mine never went above 80 last year and then I changed the thermostat and coolant temp sensor and it sits right at 90ish which from what I read is normal. I was driving on the highway at 75 mph.
Old Jul 12, 2003 | 04:25 PM
C280Sportster's Avatar
C280
Re: c280 operating temp
1994 c280
Are you sure going to thicker oil is going to help ?
What oil are you using ? I'd switch to mobil 1 if you aren't already using it.
0w-40 or 15w50.
Old Jul 12, 2003 | 10:31 PM
Steph's Avatar
If Garff did the work on your car make sure that the Antifreeze level is not too high......their antifreeze/water ratio is very high........I just had them do a service and my car heated up quickly and went to about a 100 before settling there. Brought the ratio to about 45-50 % and added a little water wetter and all is well.
I am also guessing you went up Parleys....well, that is a very hot canyon anyways.....
Old Jul 13, 2003 | 02:06 AM
SLCPUNK's Avatar
Nice to see someone from Salt Lake! I drive up to Deer Valley for work, so yes it's quite a hike. I don't deal with Garff, what I can't do myself I take to Max's Mercedes. I changed the oil out today and it was a tad lower, but I suspect that the ratio is off a bit. I'll check that tomorrow or Monday and flush it if I have to.
I'm not too worried. But I'm curious if you guys think 110 is too high for those conditions? It would drop back down to 90-100 once I was over the hill and entering PC. Thanks for your thoughts.
