Bleeding ABS Brake Systems
I assume one would need the SDS Laptop to actuate the ABS valves in order to properly bleed the ABS system on current Mercedes vehicles ?
Would I be correct in assuming this ?
The calves were not a factor in bleeding the brakes on my ABS equipped Denali. Is MB ABS that much different?
You need to use a pressure bleeder to flush fluid of ASR as well as brake lines. Cars without ASR can be bled conventionally ( no pressure bleeder required).
you are correct, to PROPERLY bleed/replace the fluid you would need to pulse the valves.
The dealership would put alternative fluid in our brake systems?
I've never heard of this before (not that I'm omniscient). Does a power bleeder do this? I doubt it, but once again I don't know. As far as replacing brake fluid....MB recommends it every two years for my car ('01 C320) and they replaced it for free during my last 'B' service (48K miles). I think replacing brake fluid should be based on the amount of water in the brake fluid which can be read with a cheap tool/sensor and not based on time. Does anyone know anything about the accuracy of brake fluid hydroscopic testors?
