87 190D Heater Woes
87 190D 90 300D
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Wondered if anyone could help me with problem. We had to replace the heater core in our 87 190D. In doing that we made the mistake of not marking three of the vacuum lines that run to the base of the console. They are green-white, green-blue, and green-yellow. I have not been able to find any diagrams that give me the proper installation locations. There are two actuators: one on the bottom with a single outlet and one above it with two outlets. I know green-white is the vacuum line. Anyone know where I can find a diagram or how they should be connected? Photo attached. Thanks.
87 190D 90 300D
Thanks, Roy. I am checking it out. It is hard to tell, but I think your drawing is for components on the inside of the engine compartment? The actuators that I am dealing with are in the cabin. I think they control opening the flaps for the two heat vents on the sides of the center console inside the car. What do you think?
04 E500
We used to have a 1987 190E 2.3. Gave the car to the Salvation Army, but didn't figure they'd have any use for the manuals, so I kept them. The clips below might help. They're from a vacuum diagram in the Climate Control Service Manual, which also covers the 190 D:
![Name: Color Code.jpg
Size: 23.2 KB](https://mbworld.org/forums/attachments/mercedes-tech-talk/240903d1343758548-87-190d-heater-woes-color-code.jpg)
If that's not enough, or it's not what you're looking for, let me know and I'll see what else I can find.
![87 190D Heater Woes-vacuum-diagram.jpg](https://mbworld.org/forums/attachments/mercedes-tech-talk/240904d1542237082t-87-190d-heater-woes-vacuum-diagram.jpg)
04 E500
You're welcome, glad I could help.
I assume you missed it or you would have gone there instead of here: MBWorld has a specific forum for the 190/W201's. It's at https://mbworld.org/forums/190e-w201-60/.
Also, check your Private Messages for a special offer.
