Fuel Problem
Old Oct 22, 2012 | 10:53 AM
Raul Casas's Avatar
1998 C 280
Fuel Problem
I have a 1998 C 280. Starts fine, runs for 5 minutes until it heats up, then shuts down - no fuel is getting to engine. Bad Fuel Pump ? When it first happened on the road, it seemed to run out of gas (it has gas). Just before it shuts down, it smells like burnt something. No error codes listed. Cools down and then starts fine, runs for 5 min. Endless loop !
Fuel pump ? Fuel injection ? Any ideas ? Thank you, Raul
Old Oct 22, 2012 | 04:01 PM
PelicanParts.com's Avatar
SPONSOR
Answer
I would suspect:one of the following.
* failed crank shaft position sensor
* the K40 is bad.
* the fuel pump has been superseded at least three times. 000 470 63 94
* the engine control module is defective.
Crank shaft position sensor
MB# 0031539628
http://www.pelicanparts.com/cgi-bin/...39628&x=10&y=6
fuel pump, superseded three times
MB# 2024703941
Sub Category: Engine Electrical
Description: Overload Protection Relay-(K40 Relay)
MB# 0005400072
http://www.pelicanparts.com/cgi-bin/...0072&x=41&y=13
Application list:
C230 chassis: 202.023
C230 Komp chassis: 202.024
C280 chassis: 202.028 from 1997
C36 chassis: 202.028 from 1997
C280 chassis: 202.029
C43 chassis: 202.033
CLK320 chassis: 208.365
CLK430 chassis: 208.370
CLK55 AMG chassis: 208.374
CLK230 Conv chassis: 208.465
CLK430 Conv chassis: 208.470
CLK Conv chassis: 208.474
E320 Sedan chassis: 210.065
E430 chassis: 212.070
E55 AMG chassis: 210.074
E320 4M chassis: 210.082
E430 4M chassis: 210.083
E320 Wagon chassis: 210.265
E320 4M-W chassis: 210.282
I can't give you a part number for the engine control module, it is matched to your VIN#.
It has been superseded many times, and requires dealer programming to install.
roy@pelican parts.com
