Weird head-rest problem on clk w209!?
thank you.Mats
Here is what I did:
-Took the seat's back cover by unscrewing the two screws at the bottom of the cover
-Removed the headrest by pulling it out of the two white cups that hold it there.
-Pushed the motor assembly to the right (towards passenger seat) and removed it.
-Removed a black cover on the motor assembly which hides a gear.
-Removed the motor from the assembly
-Removed the connector/board from the motor which WAS THE PROBLEM. The solder joints from where the cable connects to the motor were bad and loose. (picture at the end).
-Re-soldered the 4 joints and put everything back together.
Now everything works perfectly. I'll be more than happy to provide more details if needed.
^ You can see the 4 solder joints on the right and how they are almost empty. I re-soldered those.
