Jump Start = Major Problems ?
Old Jul 30, 2003 | 04:52 PM
ckNSX's Avatar
My car battery was weak recently and I had jump started my 1999 SLK230 several times. I thought I had fixed the problem by charging the battery , but it died again, and this time when I jumped it, the idle kept surging between 1000-1300 rpms and there was no response from the throttle. I have searched the archives and have already tried disconnecting the battery. I have also used an OBDII scanner to pull codes and didn't get any. The BAS and ASR lights are both on. I am at a loss to what may be causing this problem, but am afraid to bring it in to the dealer because I know they will just start replacing parts. Has anyone experienced this in there cars or knows of the cause and more importantly, the fix? I'm sorry, I forgot to mention that I replaced the battery with a brand new MBZ battery and the problem still persists. Anyone?
Old Jul 30, 2003 | 05:18 PM
dtkw's Avatar
1986 560SEL, 97 BMW 740iL
Average peak lifespan of a battery is 5 years and anything after that is pushing it. I replaced mine 3 years ago when I noticed things were slowing down a bit here and there. And I did not get a MB battery, just a Sears Diehard International. People here are saying Interstate is better, I dunno.
In your case, perhaps the alternator is not charging the battery, check that too. If you had a volt meter, you can do it yourself.
Old Jul 31, 2003 | 12:57 AM
quietflight's Avatar
to fix the problem,
REPLACE THE BATTERY
i wouldnt say that the avearge life of a batt is 5 years, i had a 1991 integra that i put my first batt in after almost 9 years of use.
Old Aug 1, 2003 | 10:15 AM
ckNSX's Avatar
I've already replaced the battery, as it says in my first post.
Old Aug 1, 2003 | 12:54 PM
Mark08859's Avatar
2008 C300 Sport
Bring it to a shop where they can check the electrical system. Also, I'm not sure that MB gives a 5 year battery. It may only be a three year one.
Old Aug 1, 2003 | 10:16 PM
KrispyK's Avatar
Porsche 997 C2S
I think a likely cause would be a failing alternator. Most gas stations these days seem to have an alternator diagnostic system. You should have them check it out.
Old Aug 2, 2003 | 08:21 AM
mdp c230k's Avatar
2002 c230k
Re: Jump Start = Major Problems ?
Does the surging still happen? Does the new battery go dead?
Old Aug 2, 2003 | 12:00 PM
ckNSX's Avatar
Yes, the problem was the same with the new battery. The car is now with the dealer and they have not yet figured out the problem. They have ordered an ECM unit to test with.
Old Aug 2, 2003 | 01:06 PM
mdp c230k's Avatar
2002 c230k
Possibly a faulty MAF sending bad numbers to the ECU. It won't throw a code since it's not dead just sending bad data.
