Patrick or MB Tech A/C Compressor Noise
Many thanks
I was not able to read the labels (there are 2) on the compressor that well, as I have limited visual access, but from what I could see I did not find a similar # to what you gave.
*It is a buzzing/humming noise when the a/c is on and car is hot. Sometimes its always buzzing and other times not, but you can still hear just after you turn the a/c off.
*The noise will apperar when a/c is first turned on and even louder when first turned off, then it stops.
*The car was produced this July.
Thoughts please.
Regards,
Has your dealer already tried this? Does the noise change when holding the hoses?
Your problem is certainly not a "known" problem (so no similar experiences, except for that part number mentioned before).
Does the part # you mention apply to 2004 models?
What is the exact name of the valve you are speaking of?
I'll try to hold the hoses and see what happens.
Noise always seems to be there just after turning A/C off then it stops.
Thanks.
The valve is an electrical regulating valve in the compressor. The compressor is not regulated by a clutch but by regulating the current to the valve (the wheel at the compressor turns all the time).
Sounds like this could indeed be my problem, I hope it right's itself
Thanks again, your help is most appreciated.
The compressor on my 03 was quiet. Do you have that humming sound on your's that can be noticed in a garage etc ?
I noticed a mild constant humming/buzzing noise which is coming from the A/C compressor area, when I turn the A/C off the noise stops. The noise just started today. Any thoughts or similar experiences?
Many thanks
MBTECH 208 now that you're back any thoughts? Does the info Patrick from Belgium suppplied apply to the US?
