Replacing a/c compressor
Old Mar 24, 2013 | 10:42 PM
Rrussell30's Avatar
C220
My a/c compressor went out on my 1996 c220. I'm wanting to replace it myself. Outside of the compressor, what else would I need to change or do? Thanks
Old Apr 3, 2013 | 03:40 PM
Chrisblack99gt's Avatar
2003 S55
You need to evacuate the A/C system. If you don't have a machine (which I'm sure you don't) go to a shop and get it evacuated. After you evacuate the system, re+re the drive belt and replace your compressor. Take it back to the shop and get your system filled w/ refrigerant. Make sure they add dye to the oil so that you can tell if there is a leak. I would highly recommend replacing the o-rings on all of the lines that attach to the compressor while you have them out. A few cents will save you a leak and a hassle down the road.
