Slk R171 TPMS (RDK) retrofit help requested
SLK 55
Hi all
I've signed up and introduced myself - great site btw....
One of the main reasons for signing up here is for some assistance with a TPMS (or RDK as its known in Germany) on a 2005 R171 SLK
First, some back ground...
This is a retrofit using the correct MB part from a 2008 vehicle, amd the correct wheel sensors for the Highline TPMS (option 475)
UK Car... AMG model
DAS Version 03 2012 on a Dell Laptop, Chinese clone MUX
The hardware is installed (wheel sensors and the ECU in the rear electronics bay) and connected up. It's been through the initial startup and as far as DAS is concerned, it's fully functional - I can see the actual tire pressures and temperatures (after the wake up period) and all of the activiations and messages (in the actual values section)
CGW is configured to show the options for the Tire Pressure Monitor (option 475) and the Tire pressure warning is disabled (both in the CGW module and the ESP module)
Using Dev mode DAS, I can enable the car outline display (from the main mileage reading, press up on the steering wheel arrow buttons to get to this once enabled) and the reset button on the side of the cluster then acts as a reset for the TPMS values - when pressed the screen changes to the 'Are tire pressures correct' screen, and you can select Yes or No with the + /- buttons on the wheel..
The snag is there is now pressure displayed, just dashes...
Inspection with DAS shows an error in the IC - 9115 - Fault in CAN communication with the control unit RDK tire pressure control....
I also get a malfunction showing on the dosplay when starting the car - picture of a tire with an exclamation mark and the message saying Display Fault, visit workshop (if I disable the car outline display in the variant coding section of the IC this error goes away, but so does the TPMS display....)
Kind of stuck now - been through stacks of options, had the car set as US / CDN as opposed to ROW and re done the initial startup, checked all of the variant coding options in the RDK (N88) module - all seem fine...
It's odd - I can access and fully interrogate the TPMS ECU in DAS and read all of the correct values (it shows pressure and temperature changes when they have been made), it just seems that the TPMS ECU isn't talking to the IC - have I missed anything or has anyone else got any extra info on the TPMS retrofit...
Many thanks
S
UK Car... AMG model
Many thanks
S
SLK 55
Hi
thanks for the reply...
The wiring harness is fine and has been checked out...
I've taken delivery of a second TPMS module and hooked that up - after doing an Initial startup of the module things are exactly the same. I've even used a different harness / power port and link into the CAN network....
As before, the module(s) are available to DAS, report the correct pressures and temperatures and work as advertised, just not updating the display on the Instrument cluster - the car outline is left with dashes where the values should be...
Numerous resets via the R button on the side of the cluster make no difference.. (these are logged in the TPMS ECU so I can confirm that the reset is working...)
Odd eh..?
Cheers
S
Odd eh..?
Cheers
S
SPONSOR
Hmm
Scratches head..
I can only conclude there is a software configuration or compatibility issue.
whunter@pelicanparts.com
it takes about 10 miles or so for the tire pressure to reset after you clear it. i'd reset and drive it for a while to see if it senses the tire pressure.
