Oil Change Question
Side Note: Don't try to change the oil in a car that holds 8.5 qts with a 7 qt. oil pan. Don't remember the last time I scrambled that fast to find another drain pan!
1. MB calls for the oil to be changed every 10K miles. I've never owned a car with an oil change interval that long. Even when using the type of oil recommended by MB, do you still recommend going that long, or are shorter intervals a better idea. I'm not hard on my cars and don't drive under extreme conditions.
2. I've done hundreds of oil changes in my life, and after the oil change the oil on the dipstick is usually quite clean. I noticed on my car that even after the change the oil was more discolored than I'm used to seeing. Is this normal due to the 10K intervals?
3. If the darker color of the oil isn't normal, should I do something like change it in 5K miles (35K), then again in another 5K (40K) to help clean out the buildup that is discoloring the oil.
4. For those of you that do your own services, have you found it difficult to find appropriate oil. According to the book, due to summer temps here I need an oil with a top viscosity of at least 40, but finding any full synthetics above 30 was nearly impossible. The only full synthetic I could find was Castrol Edge 10W-40, which could be problematic for the coldest part of the winter. I really hate the thought of having to have oil shipped in just to get the right type/weight of oil.
